Текущее время: 18-09, 03:01
Начать новую тему Ответить на тему  [ Сообщений: 1050 ]  На страницу Пред.  1 ... 44, 45, 46, 47, 48, 49, 50 ... 70  След.
 Заголовок сообщения: Re: Курилка в Альтернативные...
СообщениеДобавлено: 03-07, 10:50
Троллем меня обозвали. :evil: :live-39:
За то что нет,даже не пытался подвергнуть сомнению работоспособность.
Просто предлагал свои варианты,свои идеи.
Говорят,работает все и так,не нуждается в усовершенствованиях.
Holcomb - Methods and Techniques that lend themselves to the Appliation
Since the windings (coils) are stationary and can be or are individually controlled (switched), a variety of techniques could be applied individually, or in combination, to this device to achieve excess energy.
1. BEMF manipulation - as explained above in BEMF Sequence.
2. More than one induced winding (coil/flux) can be excited by a single inducer winding (coil/flux). This method is evidenced in a variety of claimed excess energy devices (a single central coil "fluxing" many surrounding coils).
3. Manipulation of the di/dt and/or dv/dt inducer waveform (variable/modulated flux w.r.t Faraday-Lenz - by definition).
4. Gains are also achieved by the use of fast rising signals, high voltage/low current, high frequencies, steep BH curves, etc.
Use of the "motor frame" might be for convience only (rotor, stator, windings already exist and are easily obtainable). Tap the windings/coils as required and simply "switch" them in whatever sequence you determine via relays or SiC (fast, low on resistance, high voltage) MosFETS and controller/computer.
On it's face the concept provides a lot to work with - controllable fixed windings (and lots of them) - a suitable enclosure.
A rotating magnetic field replacing a conventional generator rotor - what's to be gained there? You see a "few poles" every revolution?
See them all, all the time, always aiding. Your not trying to move anything - just create flux interaction and reduce losses/BEMF!
СообщениеДобавлено: 30-07, 10:30
phpBB [video]
Ну посмотрите,народ во всю клепает уже сколько лет
эти чудо-девайсы. Неужели это все брехня ?
СообщениеДобавлено: 01-08, 20:43
главный колбасист писал(а):
эти чудо-девайсы
А в чем заключается чудо? Что на выходе?
СообщениеДобавлено: 02-08, 19:42
На выходе якобы в четыре раза больше мощность чем на входе.
Народ инвестирует туда гроши,акционерные компании,и все такое.
И все это потому,что как они утверждают,вращение поля достаётся
нам на халяву.Не надо,обливаясь потом,крутить ротор в статоре,
преодолевая силы противодействия.Всё что нужно,только успевай
переключать обмотки.
СообщениеДобавлено: 03-08, 14:31
И все это потому,что как они утверждают,вращение поля достаётся нам на халяву.
Какая чушь?! :smoon: :nea:
На то и развод. В МММ тоже многие "инвестировали" свои гроши.
СообщениеДобавлено: 03-08, 19:10
Да,но они проводили эксперименты с трёхфазным генератором от
бензогенератора,запитывая статор,а с ротора снимая нагрузку.
Ровно все наоборот. И утверждают,что ток потребления статора
не увеличивается при увеличении нагрузки.
А вот мой,скромный эксперимент с
моторчиками BLDC.то же самое.
Правда,и мощи на выходе
кот наплакал...
СообщениеДобавлено: 03-08, 20:27
Т.е., статор имеет трехфазную обмотку и ротор имеет трехфазную обмотку? Ротор заторможен и находится во вращающем поле, генерируемом статором?
Если так, то мы имеем дело с 3-х фазным трансформатором. У трансформатора ток в первичке зависит от тока нагрузке во вторичке? То то же!
СообщениеДобавлено: 03-08, 21:50
У меня вовнутрь BLDC статора от мотора винчестера засунут
якорь от обычного коллекторного двигателя. У тех жмуриков,
был взят стандартный трёхфазный генератор от бензоэлектро-
станции.Он двухполюсный. У обычных трёхфазных трансформат-
оров,разумеется ток в первичке зависит от тока в вторичке.
В этом случае,никакой обратной реакции не наблюдается.
СообщениеДобавлено: 03-08, 23:19
У тех жмуриков, был взят стандартный трёхфазный генератор от бензоэлектростанции.Он двухполюсный. У обычных трёхфазных трансформаторов,разумеется ток в первичке зависит от тока в вторичке.
Полная ерунда. Трехфазная вторичная обмотка является лишь частным случаем. В этом случае три фазы преобразуются в три фазы. Однако каждая фаза вторичной обмотки работает независимо. При изменении количества фаз вторичной обмотки происходят те же процессы, но изменяется фазовые сдвиги между обмотками.
Также вращающее поле используют классические электротехнические фазорегуляторы (фазовращатели). Там трехфазная (или n-фазная) подвижная обмотка находится во вращающемся поле. При изменении положения этой обмотки в поле, изменяется фазовый сдвиг напряжения в ней. Однако закон трансформатора все равно сохраняется. При увеличении нагруженности вторичной обмотки, увеличивается ток и в первичных обмотках (с учетом фазового сдвига).
При необходимости, хороший фазорегулятор можно сделать из двигателя с фазным ротором.
phpBB [video]
СообщениеДобавлено: 04-08, 11:22
https://www.sinref.ru/000_uchebniki/00850_energetica/008_Spravochnik_po_elektricheskim_mashinam_kopa_1988/083.htm?ysclid=l6elj9d7r5925658721
Ничё себе. Какой ерунды только не бывает.
Жмурики там тоже перегрызлись меж собой,Веслик говорит
тоже что это все фигня.Большинство не верят,спорят.
А в моем случае нет обратной реакции на нагрузку
наверно потому,что в статоре в разы мощность
рассеивается,горячий,в насыщение видать
входит,больше,чем на выходе.можно
просто не заметить.Частоту
больше надо,наверное.
СообщениеДобавлено: 09-08, 15:30
phpBB [video]
СообщениеДобавлено: 09-08, 18:20
:good:
Очень интересное видео!
Ссылка на все учебные фильмы этого ютубканала.
СообщениеДобавлено: 10-08, 15:25
Хорошее.
А в самом начале того ролика,кого вращало поле наведённое трёхфазным статором? Это и зацепило, но было вскользь сказано,и они перешли на механику.До меня не дошло.
И повышающие магнитные редукторы,гуглим,и не находятся ничего,в основном
понижающие.Так понимаю,на повышение плохо они работают,и Белецкий показывал
это. Для того,чтобы захватило виртуальное поле "первичный вал" такого редуктора,и увеличить "обороты" хотя бы раза в два. И это dФ/dt наведёт нам
больше ЭДС.https://mypresentation.ru/documents_6/1d0d0190e15c8806e203a7d01af5178d/img26.jpg
Хлопцы проводившие эксперименты с синхронными генераторами на несколько
киловатт"наоборот" не обнаружили обратной реакции повышения потребления статора от нагрузки.Делали бегущую волну коммутируя статор механическим щеточным коммутатором.А до такого они не додумались.
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/dlattach/attach/187792/image//
СообщениеДобавлено: 10-08, 22:27
До меня не дошло.
Лучше понять принцип работы позволяет вариант двигателя с ротором, имеющим одну точку касания со статором. Такой двигатель описан в патенте Москвитина (заявлен 1944 году, а выдан в 1947 году). И если ротор катится по внутренней стороне статора в одну сторону, то вращаться он будет в другую. Как в классическом редукторе. Там тоже две связанные шестерни вращаются в разные стороны. Однако, в тихоходном двигателе шестерни находятся одна в другой и поэтому за один полный оборот поля, ротор поворачивается на угол пропорциональный разнице длин поверхностей статора и ротора. Если ротор и статор выполнены в виде шестеренок, то угол пропорционален относительной разности зубцов статора и ротора.
СообщениеДобавлено: 11-08, 10:42
Теперь дошло. :D
А как мне всё таки повышающий обороты магнитный редуктор сделать?
И правда ли говорят,что у них потери даже меньше чем у механических?
p.s. Там вспомнили и вытащили на свет божий ещё одного деятеля,
который использовал похожий принцип пару лет назад,и якобы
добился успеха.
phpBB [video]
